Any alternative to foam for under the fuel tank?
I am about to re-install my fuel tank and not sure how well we will be able to get the foam completely under the tank. Access to the high side is limited because the tank sits under the lip of the cockpit floor.
I had though about using foam insulation sheets to fill the 1" void between the tank and hull. I have concerns about it's durability, strength, and if it will "melt" if any gas should come in contact with it.
Enjoy the show
I think you want bilge water to be able to flow under the tank.
You can install several staws prior to installing the tank. Then just hook the foam bottle to each tube and fill a different area.
The Illustrious One
In the past I have installed some PVC pipe about 1/2"-3/4" O.D. next to the center stringermake sure it runs through each of the bulkheads unobstructed then set your tank on a couple of foam strips 1/2" wide by 1/2"-3/4" tall that run from the side down to the center stringer like the bulheads run to raise it off the floor. Then mount the tank with hardware at the top to through bolt it to the stringers. You can either then remove the strips which is probably best to get an even pour. Make sure there is space all around the tank to let the foam expand into place around the bottom and sides. Once you have the tank suspended in place get the two part foam you have to mix together. Once you have it mixed pour it from the outside of the tank down the side and it will expand into place. Keep an eye on it as once it starts to expand it will do it quickly. Dont be afraid if it runs over the top some as you can cut it after it sets to get a nice uniform finish to reinstall the floor over. If you have any questions please PM me your number so we can chat and I will walk you through it.
Good Luck
Sean
Good Luck
Sean
Dying,....Is the day worth living for!!!!!!
1 Post
Sean,
I remember the way that you and I installed the tank. But the last time I saw this job performed on a similar boat, they added one step that we forgot. Leave the boat uncovered with no interior and all of the electrical components hanging out in the rain for three or four days to let the entire project get soaked. Why didnt we think of that. Hmmmm? Oh well, I guess they did a good job, the boat runs....Oh...Wait...No it doesnt!
The Illustrious One
Thats the difference between dedication to the client and screwing him over just to get the job in for sake of being the Big Man who we know he's really not.
OK, here's the problem. When the tank is in place it sits under the cockpit liner and there is no way to access the outside edge to pour the foam. And there is no way to see if we got it completly filled.
1 Post
Dammit Man, cant you see we are trying to pick on people here! You keep bringing up of all this technical mumbo jumbo! Kiddning.
Where do you have to poor from and how large is the area. You only get one shot to do this right or its Scraper time. Did you pull the floor?
THe floor is out and tank is ready to go back in. I am going to use poly foam sheets from Fiberglast.com. Their site says it has the same properties as the 2 part foam. This will go on the bottom only and the rest will be 2 part foam.
