Anyone had a trailer powder coated before? >
Old 07-29-2003, 08:32 AM
buck183's Avatar
Originally posted by Jan
I was thinking about Rhino Lining my trailer, any thoughts on this.
Jan
I may be able to help a little on this idea.
I spray bedliners for a living. The amount of chemical it would take to coat my trailer at my cost wouldn't be worth it for me to do myself. There's also an issue of getting EVERYTHING coated good. I don't think it's possible to get into every spot and crack and do it correctly. This coming from someone that has sprayed over 200 bedliners this year alone.
If it's done correctly it would be a good product to use. Although I wouldn't recommend using "Rhino". I would recommend using someone that sprays a hot, high pressure liner. The end result would be better.
Buck
buck183 is offline
Old 07-29-2003, 08:40 AM
Check with BruceK from the board. He is as HONEST as the day is long. He will tell you if it is worht it or not. I know several people he has turned down simply because the cost to them would not be worth the work. He is a GREAT guy and does fabulous work. I know several OSO members that have had fantastic success with Bruce. He is an OSO sponsor and his company is called Thunder Coatings.
Shane is offline
Old 07-29-2003, 11:23 AM
Cignificant's Avatar
I had my k-planes and some hand rails coated two years ago by a local shop. They had corrosion on them and were sand blasted. They are already peeling, and look horrible. I have also heard that the zinc-primer helps - I'll probably have them re-coated this winter by someone that has more marine experience.
Steve Gresham
'03 Donzi 33ZX
Cignificant is offline
Old 07-29-2003, 01:30 PM
buck183's Avatar
Originally posted by Cord
Does that $300 include the blasting? For powdercoating to grab, the trailer must be blasted to a near white metal condition. Pretty tough and time consuming.
Tim...Price does not include sand blasting. I agreed to bring it to him alread blasted. I have a guy that does all the sand blasting for my shop that will do it for somewhere in the area of $75-$100. I still feel like I'm money ahead though.
Thanks for all the tech info and heads up guys. I'll check with BruceK and get some feeback from him on what I'm planning on doing.
Buck
buck183 is offline
Old 07-29-2003, 02:45 PM
Roger 1's Avatar
Powder coating is very impact resistant but offers no protection against corrosion like a good epoxy primer would.
I would`nt do it.
Roger 1 is offline
Old 07-29-2003, 09:10 PM
Bad Girl's Avatar
Powder coating is excellent against corrosion, that is why the auto manufacturers use it. But on used equipment, it is worthless unless the surface is prepped properly. If you are having it blasted and then taking it to be coated for $300, that is an excellent deal. - My husband used to own a powdercoating shop before selling it, and these are his comments.
47 Lightning SE
Bad Girl is offline
Old 07-29-2003, 09:43 PM
buck183's Avatar
Thank you for the reply. That was pretty much what I was thinking.
Buck
buck183 is offline
Old 07-29-2003, 09:50 PM
Roger 1's Avatar
Auto manufacturers use powder coating in some instances to reduce costs, cut down on voc emissions and to reduce toxic waste. They still use epoxy primer ( E-coat) on body panels and other assorted components.
Roger 1 is offline
Old 07-29-2003, 09:53 PM
I would`nt do it.
total bull****
SLINGSHOT is offline
Ginger or Mary Ann?
US1 Fountain's Avatar
Wouldn't this require a BIG oven?
US1 Fountain is offline
Quick Reply: Anyone had a trailer powder coated before?
