Stains at the water line
Old 08-01-2003, 04:58 PM
Registered User
bcoffield's Avatar
Default Stains at the water line
Just got back from 7 days of boating on the Upper Chesapeake. Had a great time. However, now that the boat is back on the trailer what is the best way to remove the stains on the bottom of the boat and at the water line?
Simple greem is not cutting it!
bcoffield is offline
Old 08-01-2003, 05:05 PM
Von Bongo's Avatar
Zep toilet bowl cleaner just melts it right away. It is acidic so rinse and wax after.
used it all the time to remove the Missouri River scum.
Von Bongo is offline
Old 08-01-2003, 05:06 PM
I found that a mag wheel cleaner made for polished wheels works great! You just spray it on and hose it off. Also Marykate on/off sold in West marine but it is more expensive and you need gloves to use it.
Gary C is offline
Old 08-01-2003, 05:16 PM
muffman's Avatar
Smile
Oxy Clean works really well getting on river slime. You can get it at your local WallyMart.
muffman is offline
Old 08-01-2003, 05:19 PM
Registered User
36spectre's Avatar
Any toilet bowl cleaner.Otto
36spectre is offline
Old 08-01-2003, 05:35 PM
Charter Member #37 /Moderator/Platinum Member
vagrant's Avatar
I use Ringo.
Champagne taste on a beer Budget
C. P. B. A. Carolina Power Boat Assoc
vagrant is offline
Old 08-01-2003, 06:56 PM
East Coast B's Avatar
Slimy Grimy is good, not as toxic as marykate onoff, but on/off works better. I mix slimy grimy in a 2 gal weed sprayer, makes it easy to apply. The on/off will eat away the rubber washers in any sprayer. First thing I do after salt water is put the boat into a freshwater lake and clean the hell out of it..... same with the trailer... I love my disc brakes, so easy to clean, no rust....
East Coast B is offline
Old 08-01-2003, 07:25 PM
ActiveThunderTodd's Avatar
Sno Bol is the best stuff I have ever found. Simply wipe it on and watch the stain vanish.
ActiveThunderTodd is offline
Old 08-01-2003, 08:02 PM
ofshore's Avatar
Heller Glanz black streak remover works pretty good and it doesn't take off the wax.
ofshore is offline
Old 08-01-2003, 08:08 PM
vagrant's Avatar
Who sells Sno Bol. Some one else has recommended that and I can not find it anywhere
David
vagrant is offline
Quick Reply: Stains at the water line
