O/T Advice on Truck Tires Needed
Moderator
Dang... someone beat me to this... I am about to put new tires on my truck as well. A 02' 2500 HD, it has 16" wheels from factory on it. Stock size is 245 75/16 I was looking to go up in size as well. I am not sure how large I can go on that wheel. The BFG's are what tire I am putting on the truck. Anyone know the largest size I can go to, and who has them cheap?
Charter Member#157
Originally posted by svilla
I think you would have to install a mild lift with those tires at least a good 3 inch for off roading or 2 inch just for street use. What brand are you planning on using? If you have a chance check out some Bridgstone Dualer Revo's I have them and they are the best all around tire I have owned. No road noise, no hydro plane at 65, and lots of traction.
I have had bridgstone on my last 4 trucks
Just put the Revo's on the dodge, Great tires no noise and great mudding too
This Cat is trying to keep up with the Big Dogs
Have had 'em all...Dueler Revos...no contest! Quietest, best riding, highest traction, high tech tire of it's kind! Now available in E load range also! It's the best of all worlds for a truck that actually get's driven and used everyday. ChrisK...You can put 285's on that HD..though I chose not on mine 'cause you have to trim (mild) and crank T-bars (this isn't always enough if you plow/especially with a Fisher)...not to mention that section width is just plain unsafe on a 6.5" HD alum. rim. I run some pretty high speeds and just dont like the idea for a number of reasons in respect to tire/wheel seperation/rolloff. If you tow and run any air in 'em (285's)...they'll wear down the middle on a 6.5" rim. Also consider if you tow, the gear ratio to the ground lost in additional tire diameter! (pretty significant from a 245~285) Put 265 Revos on that HD...all around you'll be very happy!
Moderator
I was just about to say, plowing in Orlando... hmmm... if it ever snows here I am moving south! I was looking at the 265's to put on it. A slightly larger tire, yet not huge. A friend of mine has a set of BFG's and with over 50K miles on em, and they still have A LOT of tread life left.
Rippem... What part of upstate are ya? I will be headed that way in the end of november(thanksgiving week) to visit family etc.... Albany, schenectady, and fonda/fultonville area...
An hour north of Syracuse...20 mins. south from Alex Bay/1000 Islands St Lawrence River. If I turn right out my driveway, I'm 20 mins from Lake Ontario! The season is only 5-6 months at best...but it is the nicest FW boating on the planet
The new F150 has coil over suspension with "A" Arms
the shock tower is very high on the frame because the stiff frame allowed more suspension travel ( because less frame twist)
possibly resulting in the same overall wheel travel, i don't recall, but more suspension travel anyway
i'm sure when i get to SEMA i will see lots of options, problem, i may have my truck by then. maybe i should jsut wait and see what i can find a SEMA
otherwise good advice mitch, 305's would look cool
Moderator
Yeah the firestones are not holding up all that well. That and because I have a BB in it and every time it rains around here all I have to do it sneeze on the gas pedal and it spins the tires.
