Bravo Low-water pick-up (Cup or Muffs) >
Old 09-16-2003, 09:44 PM
Charter Member#157
MnFastBoat's Avatar
Originally posted by convincor
http://www.perko.com/flushpro/flushpro_body.html
boatfix.com has them for $46.00
shop around, you might find cheaper.
Or, just pull the hose off from the inside at the transom assembly and stick a hose inside you intake hose.
you could put some fittings into the bottom of a 5 gallon pail and fill it with antifreeze.
I made a set similar to the perko
I wanted to make sure the antifreeze dropped back into the drive water jackets. The Perko is spring loaded to allow in the water flushing.
I just went to Home depot and peicd some pvc connectors together. Want to finish it off with a transom setup to hook up from the outside.
Spent less the 25 for twins
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 09-16-2003, 11:02 PM
Bruce, I picked up the Merc piece the other day that goes over the lower p/u. Now all we need to do is goto Wally World and get a $5.00 regular flusher.
F1-00 Racing is offline
Old 09-17-2003, 10:26 AM
FunHome's Avatar
I was going to do just that, then I looked at it, and with the silent choice exhaust I figured to heck with it I'll just do it from the outside!! (it kinda tight back there!!)
This winter I plan on pulling the motors and while they are out I'll plumb a water outlet like what you guy's are talking about!!
Thanks!!
FunHome is offline
Old 09-18-2003, 06:02 AM
Default Hey Brian
For that kinda dough, might as well go for a mounted hose fitting somewhere in the engine compartment or through the transom. Sonic installs them factory on the swim platform. Could not be slicker.
Is there a valve that shuts to prevent water from flowing back to the drive?
Next time you're in the River, call me. I'd like to see this set up.
Shah Mat is offline
Name That Boat.com
Drives and Lower Units
4
09-20-2007 10:04 PM
dreamer
07-17-2007 05:24 PM
Shah Mat
0
07-06-2007 07:31 AM
skygod
1
06-16-2003 08:31 AM
skygod
08-22-2002 08:46 PM
Quick Reply: Bravo Low-water pick-up (Cup or Muffs)
