Bravo Low-water pick-up (Cup or Muffs)
![Question](/forums/images/icons/icon5.gif)
All my other boat's have used the older style muff's.....
But my baja has low water pick-up bravos and I would like to be able to start it out of the water for winterization.
Where can I get, I guess it's a cup??
for the front of the drive??
How much are they??
How much are they??
Originally posted by Troutly
Any place that sells Merc parts should have them.....about $65 retail!!
![EEK!](/forums/images/smilies/eek.gif)
Forum Regulator
For that kinda dough, might as well go for a mounted hose fitting somewhere in the engine compartment or through the transom. Sonic installs them factory on the swim platform. Could not be slicker.
Bruce,
It's another job for duct tape,
I've used duct tape to cover the
4 holes in the front of the gearcase,
then use the ear muff flushing attachment.
jt
jt
Originally posted by jt29olhp500s
Bruce,
jt
Bruce,
jt
http://www.perko.com/flushpro/flushpro_body.html
boatfix.com has them for $46.00
shop around, you might find cheaper.
Or, just pull the hose off from the inside at the transom assembly and stick a hose inside you intake hose.
you could put some fittings into the bottom of a 5 gallon pail and fill it with antifreeze.
Bruce,
jt
Bruce,
jt
Bought an Imco low water pick-up flush kit from www.cpperformance.com . Fits like a glove. Good price, fast delivery!
