Cracked GIL Exhaust manifolds
I have used Gil Offshore for ten seasons and finally the stainless tailpipes leaked. A small leak that caused a miss at idle. I thought that was an excellent track record.
But, if they have a problem because of some bad castings, then Gil should make good on them. Ship them out for inspection now.
Ginger or Mary Ann?
I thought the manifolds used on the HP motors are Mercruiser and only the risers are Gil? At least the casting name on mine was "Mercruiser"
I have a set of Gil Manifolds on My smallblock that are 17 years old,I stripped and re-powdercoated last year and the inside still looks like new.The boat is not docked and never been in Salt. I think that says something for an aluminum manifold.
Rob
Rob
Mine cracked in the manifolds. Right at the top where the cylinder divider walls are. Both manifolds were cracked in the same place. They were only hairline cracks, but I suspect with heat and h2o pressure, that they were leaking a decent amount while running.
The risers were also starting to get hairline cracks on the interior welds.
