Upgrading my tow vehicle to new F250 6.0
#31
Charter Member #319
Originally posted by st31
The 2003 F250 pictures at the top of this message thread has 295-75-16BF Goodrich AT's. I plan on switching out the tires to that size as well once mine comes in from the factory.
ST31
ST31
#32
Originally posted by BRUCE SEROFF
Whats the biggest/ heaviest boat you can safely tow with a F250 PSD over long distances???
I think Ford trucks, Super Duty's anyway, are way under rated, I'm sure for liability reasons. One key is having the right towing equipment.
#33
My dually pulls the 47 at 70 - 80 mph comfortably. No side to side swaying at all. my Dodge wouldn't pull the 357 at 70 unless it was downhill. I really like the ford much better. The 47 is 13500 lbs and the 357 is 10800 lbs. I was thinking of putting the 4" blocks on mine like Troutly said it is a little low when loaded down. MFB
#34
Don't do blocks, use air bags. These are the single best thing you can add for towing. When you arn't using them you deflate them and are back your stock height and ride.
#35
I've had Dodges, Fords and GM's, had the best luck with GM's as far as durability and repairs. Bought an 03 F250 extended cab with the 6.0 in August and I abslolutely love it. With out a doubt the best truck I've ever been in. I haul a lot of big boats around, I can take off from a red light with a 35 footer and beat out just about anyone next to me. Gets around 16 mpg with 5000 miles on it so far. No problems yet, starts good and runs great.
#36
I've got an late April production 03
Excursion 6.0. 2W.D. 5700 miles and no problems yet. Mine was just built after a change of injectors was made and I understand many more changes did go in
after late September production.
I get around 17-18 mpg in the city and
19-20 on the highway. 77mph normally on the highway and have gotten up to 22mpg 65 to 70 mph. The computer always says about 1 more mpg than my calculation and I figure it holds a bit more than 44 gallons including the filler tube.
Greg
Greg
#37
Originally posted by ofshore
And I thought mine had a poor turning radius 4X4 SC LWB.
![Smilie](/forums/images/smilies/smile.gif)
Seen the moonroof option yet on the CC models? It is really well done, looks great!!
Scott B
baddogz28
10
01-31-2008 04:59 PM
