why cant I use gear drives on marine engine? >
Old 12-06-2003, 09:48 AM
timucin's Avatar
which belt drive do you advice?
do yoýu have the link?
thnx
timucin is offline
Old 12-06-2003, 11:23 PM
mcollinstn's Avatar
Comp true roller timing set with Torrington thrust bearing. About $80.
Jesel Belt setup. About $850.
Either choice is better than your gears.
What will break if you run the gears? You'll break the cam, if it's cast. If you have a billet cam, you most likely will NOT break it.
Your choice.
mcollinstn is offline
Old 12-07-2003, 07:53 AM
timucin's Avatar
Jesel Belt setup. About $850. ----- too expensive,i wont
ok i go with comp cams
thnx
timucin is offline
Old 12-07-2003, 08:03 AM
AT Cult Member #3
R Addiction's Avatar
I like that one word ...Harmonics!!! To friggin' noisey for me!!! Ask Warpaint about gear drives!!
R Addiction is offline
Old 12-07-2003, 09:27 AM
WARPAINT's Avatar
I have two brand new Crane BB noisey gear drives for sale.Brand new in the boxes.Dean Nickerson's dyno talked me out of them
WARPAINT is offline
Old 12-07-2003, 09:35 AM
Crazyhorse's Avatar
Merc used a two-gear setup in their low-horse counter-rotating inboard gas engines until 1989 when all inboards went to standard-rotation, but these were a matter of necessity to retain a stock-rotation distributor and oil pump.
Crazyhorse is offline
Old 12-07-2003, 11:39 AM
Rob
Strip Poker 388's Avatar
I run a comp cams lt drive on the Camaro. Its cheaper. I dont know the diff between it and the Jesel.ere is the link on the belt drive
http://compcams.com/Technical/Catalo...L/359-363.html
Jesel the prices here are retail .
http://jesel.com/
Strip Poker 388 is offline
Old 12-07-2003, 02:38 PM
The Illustrious One
sean stinson's Avatar
I have used the Pete Jackson Gear Drive and like cigarettefirefox haven't had any problems but the best I have used so far is the Jesel belt drive by far the best I have tried. Someone mentioned earlier that if you use the gear drive from Pete jackson use the reinforced timing cover ABSOULUTELY A MUST, I think they even offer one also. Anyway if anyone has any questions PM to discuss.
Sean Stinson
Dying,....Is the day worth living for!!!!!!
sean stinson is offline
CcanDo
Drives and Lower Units
0
05-31-2008 09:59 AM
Poorsche
7
07-27-2004 11:36 AM
timucin
1
12-05-2003 04:26 PM
doright
2
06-01-2003 11:03 AM
WHITE-DIAMONDS
08-23-2002 06:36 PM
Quick Reply: why cant I use gear drives on marine engine?
