Anchoring in rough water
My Fortress holds fine in silt/mud (I've held up to 4 other boats rafted to me), but doesn't work well on sandy bottoms. Thanks for the link re: box anchors, Indy -- I'll look into that. Ditto the comments on the scope.
Actually my main concern is anchoring in about 3 to 5 feet of water. This is where we just stand around and chat, drink, eat and whatever else. However the water is very rough for a small lake. lots of boat traffic and bulkheading
Roby
Roby
Gone Fishin'
In 3-5 feet of water, sandy bottom, and lots of boat wakes, I simply use a standard danforth anchor. BUT, I have 5' of chain on mine. I also have the anchor rated for the next size up, my boat is 24', and I have the anchor for the next range up from that. In 5 feet I'll be putting out at least 40' of rode, perhaps more if the waves are bigger. We do this A LOT on the shores of Lake Michigan. Perftectly sandy bottom, no rocks, no weeds, no clay. Just pure white sand. My boat NEVER comes loose. It is important that when you put your anchor in, you don't simply "throw" it over board. Lay it into the water and then back down to where you want the boat to end up. This kinda takes 2 people I guess.... one to drive, one to set the anchor. And I do mean "set the anchor." Hold the line parallel to the water while backing down, and just before you get to where you want to end up, neutral the boat and stop it using the anchor. You will know INSTANTLY whether you got a good set or not. If you don't stop, no set! This works every time.
To keep from drifting into other boats, I carry an 8lb navy anchor in a nylon bag with about 40' of line on it. I drop it off the back of the boat, nearly straight down, and I do not drift back and forth.
I've been using this method since my father taught it to me nearly 30 years ago. I like anchoring in sand!!!!
Roby
Roby
Gone Fishin'
I've been told they do not work so well in sandy bottom areas, especially if the waves are bigger. Just what I've been told, never seen anyone use one around here. We all stick with our danfoth's.
Gone Fishin'
Like I said, no personal knowledge, just second hand drivvel I guess!!
