Has anybody stripped painted graphics from Gelcoat?
Neno the mind boggler
wildfire- i have used that trick many times and have striped entire boats like that. the trick to doing it safely is to round the corners off of the blade with a fine grit sandpaper. depending on how well the paint is bonded to the gel. sometimes i will dull the blade also. keeps it fron digging in.
oh. and you might want to wear a pair of safety glasses when doing this. it tends to fracture the paint into these sharp little flakes that fly every where.
08 OPA High Points Champion
speel chekk this fokker!
i took off a name down the side of my boat. over cleaner made quick work of the paint but made the gelcote haze up. I had to wetsand 800-1200-1500 with a spray bottle full or water and an air random orbit sander. Finished up with compound and a healthy waxxing. It was major pain in the ass but it got the large orange 80s style block lettered "pure energy" off the side of my boat.
Pardon me, while I whip this out!
I just stripped a Cigarette Bullet with a product made by Kleen Strip it is Fiberglass safe and will not hurt the gel coat you can apply it with a paint brush just do not do it in the sun it will dry to fast the Bullet had a base coat clear coat finish on it so it took about 3 coats to get the paint off when you paint it on it will take about 5-8 minutes at about 60 degrees and then you can scrape it off with a razor blade any questions give me a call 918-906-9801
Were doomed!
We used easy off oven cleaner on my buddys 28cig project a while back.....had to take off :"cigarette racing" off the side that was painted on. I wouldnt recomend it cause you have to play with the time period of when it takes effect. We got about 80% of the way through the boat with great results and then a guy left it on there about 10min too long on one side when he went to answer a phone call with us not knowing working on the other side.......
turned the gell a stained yellow! and the worse part about it is that it has bled through the new paint a little........nothing a little creative sticker work didnt fix but it did get the owner pissed off cause of the money spent on the paint job!!!
![Mad](/forums/images/smilies/mad.gif)
![Frown](/forums/images/smilies/frown.gif)
-Wally
-Wally
