Boat Builders
Charter Member #232
Boat Builders
Can you put Vinnylester Resin on top of Epoxy? I did a repair with epoxy for strength reasons and I am wondering if I can put Vinnylester on top of the repairs.
Jon
Jon
Put your best foot forward!
Charter Member #232
Bummer. Not a big deal I will just have to use more Epoxy. I was trying to avoid it to keep the costs down plus I do not like to work with the Epoxy.
Jon
Jon
Neno the mind boggler
what epoxy are you using and why dont you like it. just curious
08 OPA High Points Champion
Charter Member #232
Dave I was using West System. First it is VERY thick. So it takes a while to soak into the glass. Second it takes FOR EVER to dry in comparison to Poly or Vinnylester. It is VERY hard to get all the air bubbles up to the top.
Jon
Jon
Charter Member #232
Mr. Bravo that is kind of what I do but I put down a wet coat first. It helps a lot with the glass soaking up faster.
Jon
Jon
I use a cheap brush to apply epoxy to suface, then stick cloth, then dab with juice till soaked, can follow with roller if you have one. In my design of my restoration of my Carver for the bahama runs we desided to epoxy bulkheads to sids. That is it. all else is Glass. Alot of flexing on sides,hence a super strong flexable tab to hull sides.
Ps, But I glass tab to hull and stringers from bulheads.
Nuts Eh. But it works, I have busted more tabbing from sides to bulkhead in the past to learn.
B3
B3
