Update on 260 Sonic Prowler (Test run)
Originally posted by wwwTOPDJcom
Lab that Puppy then lets hear the numbers
That will be the true test...
Forum Regulator
Those are great numbers JL. I KNOW it has more than that. Wait until you get into consistant 2 footers.
Chevy-Harley fan
Originally posted by SOX
Nice boat, Any pics of the interior? I'm working on the wife a little bit to make a Prowler 26' our next boat... Help me out.
Pete
Pete
Big factor as a whole!
Originally posted by gmhdfan
Thought the bolster could be moved back a liitle though.
Forum Regulator
JL, I saw the close fit on the bolster/steering wheel on your boat. The steering hub actually comes in three sizes, or thicknesses, and you can get a shorter one to put the wheel closer to the dash. This will help some. I have no problem with mine, as I like the fit too; but others do not.
JL, Great speed, I guess the infused hull helped quite a bit ( the ITS system supposedly helps this boat also), I wonder if Sonic has changed the x dimension with the ITS. In the picture of the engine compartment, what's the fiberglass structure to the left of the header? Is it just a cosmetic cover for the stringer or something else? If the bolster was moved back any farther the rear seat legroom would suffer. You can't have a large cabin, walk around deck, roomy engine compartment and a big cockpit! It's only a 26' boat I have a Prowler and think it offers alot for it's size! Steve
