CG - Apache 41 / Cig 42
Originally posted by dawezel
Judging from the current drawing I got from the dock builder, if I pull a 42 in all the way until the bow is about to hit the dock, I'll have 7-8 feet of boat hanging off the back of the lift, not including the drives. I'm worried that if the CG isn't somewhere relatively near the center of the lift, it's going to strain the lift and the boat, and could be ugly if a hurricane comes through.
You want the lift bunks to extend aft to the transom. On my full cabin 40' Formula I'd guess the cg is about 15' from the transom (pretty much under the driver seat) based on my crude estimation of where to put it on the lift so the tension in the fore/aft cables is the same.
By the way, you can make the lift bunks extend behind the lift cross beams as needed to get the bunks to run to the transom and keep the cg between the two cross beams.
-Greg
-Greg
Originally posted by jody165
Wicked Won,
How did you measure your CG? Do you have to use a sling at a boatyard or is there some "backyard" way of doing it that the average person can do in their driveway? I have a 38 that I want to measure.
Thx
Wicked Won,
Thx
Thanks for all your help guys.
FeverFan:
Backing it in is an interesting idea, but I don't think I could get the cradle down enough in low tide to clear the drives.
FeverFan:
Originally posted by SS930
I would think Mark would know if anyone, but 16' sounds really far forward. If you think about the design of these boats, all the weight is in the back... to have the CG 40% forward from the transom doesn't add up.
![Confused](/forums/images/smilies/confused.gif)
