Test Run #2 seawater pump locked up!
Official OSO boat whore
Is it just the image, or is there a flat spot on the end of the vane?
Everything looks to be perfect, but I'm just not satisfied with that. Something cause it to lockup!
Originally posted by hi-perf-2000
thought you said the fuel pump was not on the same belt? i guess the motor had enough fuel to fire and run briefly?
Originally posted by lotoparty
are you sure it was the impeller that locked up?
power stearing maybe? does everything else turn ok by hand with the belts off?
