transom soot- cleaning
I use tried Frenzy on mine and works great! The soot wipes right off.
AUTOCONNECTIONLLC.COM
I use a product called Sled Brite Belly Pan Cleaner. It is actually for my snowmobile belly pan. The first time I used it, the black just ran off of my transom. I use the stuff for cleaning anything greasy or exhaust carbon. It works great and it doesn't screw up the gel coat.
www.sledbrite.com/snowmobile.cfm
I use Castrol Superclean mixed 50/50 with water and it seems to work well. Some other folks have had the ECM's reprogrammed (on 496's) which supposedly helps with the soot build-up.
I noticed that many of you say waxing helps. My transom seems to get more soot build-up right after I wax it. Maybe it's the wax or maybe I'm just not getting it all buffed off??
Originally posted by MnFastBoat
stop running premium??
Does Premium gas actually give more Soot??
I would think it would burn cleaner![Frown](/forums/images/smilies/frown.gif)
Maybe that is why mine is so dirty, because all I run is 90+
A higher octane fuel will not burn as completely as a lower octane fuel. You will actually lose power running higher octanes than needed.
As for cleaning any exhaust residue. Simple Green!!!
