Problem with ABS brakes on chevy dually
I need help trying to figure out what is wrong with my ABS system. The ABS system activates only when I am braking and turning at the same time. I know the wheels are not skidding when this happens. It never does this when I am braking in a straight line. This problem started happening after I put a Detroit Locker in the rear axle. The truck is a 2wd chevy dually. Has this happenes to anyone else? What may be the problem?
Re: Problem with ABS brakes on chevy dually
Very likely that the locker could be causing rear wheels to turn at a rate different than what the system is set up to "see". In other words without the locker the wheels would turn at a different rate and with the locker they are turning at an equal rate. Not sure how to fix that exactly, but a good 4wd shop should know about this problem as it would be common with these modifications.
1st what year dually is She..second if she is 1996 or newer she should have a OBD2 computer system and 4 wheelantilock brakes.What you will need to diag this is either a GM tech2 scan tool or I think snapon will work..Go into the software to watch the
wheel speed sensor readings should be a screen with four readings. next monitor all 4 speeds 1 for each wheel sounds like 1 is dropping out before the rest causing your ABS to think a wheel is locking and then activating..she may have a chaffed wire or a partial break in one and it is aggrivated when you turn the wheels..causing a signal interupt..Good Luck
Bob
Bob
Charter Member #232
I had the same issue with my Ford. It turned out that the rear springs and shocks were smoked and when I was in a turn the tires would hop causing the computer to freek. Since I replaced the shocks and springs I have had no issues.
Jon
Jon
Put your best foot forward!
Blown is probably right, you need to get reprogrammed.
The Locker axles may cause a reading the computer does not recognize.
Also, depends upon the year. Earlier GM's only had ABS on the rear wheels.
Wannabe
Wannabe
Originally Posted by phughes69
the truck is a 1996 with 4 wheel ABS
Bob J
oreo11zeus
19
03-28-2007 05:53 PM
Lmarth
12
01-07-2006 04:22 PM
