P & D / Volbvo 280 outdrive
anyone familiar with the old P & D boats with Volvo 280 outdrives? 25' with 350 SB? any info re build quality, handling, etc. boat looks like an old Pantera thanks
Neno the mind boggler
dont know much about the boat but i have heard the are good solid boats and competent in ruff water as well. i have had several boats with Volvo280's on them and havehad pretty good luck wih them. they have a pretty wide cross section so the can tend to blow out after the upper 60's ( i think a nose cone can help this) i know they can handel a fair amout of power also. i know of a guy that has well over a thousand hours with a 500+ HP big block and no probs so far. it is also a dual direction drive, can run either left or right hand with the switch of a bell crank arm located under the rear cover. on a side note take a close look at the drive, when merc developed the brovo they used the 280 as a guidline to their new drive. they are very similar, so much so in fact that there is a gimbal ring availiable to put a brovo in a volvo trasom plate. i wouldnt hesitate to own another boat with the 280 atached. pretty simple drive and pretty strong as well.
![Cool](/forums/images/smilies/cool.gif)
08 OPA High Points Champion
Toxic FORMULA
Originally Posted by Scott B
Dave,
First I have heard of the gimble ring for a Bravo.. Who makes it??
Yeah , that's a suprize to me too!!
i will do some searching but before i bought my first boat with a 280 i did a bunch of research on it. i had a thread going on another board, think it may have been hotboat. i got a bunch of info on it and someone posted some info pertaining to the gimbal ring. i will see if i can find it but it has been a while. if i remeber corectly it was a in kit form with everything for the conversion.
SUPER AIR
08-24-2006 06:47 AM
BajaBennett
02-19-2005 06:38 AM
