Intercom Systems
"which are the the best"...i have personally owned 3 different systems..and used many in others race boats....don't mess around...Craig at race com is the man...if ya cheap out they suck and are useless...well, unless your going 50mph behind a windshield.
http://revolutionmarine.com/shopsite...intercoms.html
This is the link to Revolution marine and their intercoms
Thanks for the info guys,What makes a good system and how much should they be for a 5-man set-up.Do you have the number for Race.com?
800 990 9941
good?...ZERO outside noise...VOX that actually works...and no engine or other electrical noise. u run MSD or have a wasted spark merc?? they are sure to cause problems...
make SURE you tell him how exposed your head will be and at what speed...
very few systems out there work properly and may need (all do) to be customized for the application AFTER you buy them....craig does A LOT of custom stuff and can build it from the first wire up!
so he will not leave ya with; i don't know what to tell ya!
For your application, hands-down Revolution Marine. For open cockpit applications the throat mic system gives you ZERO wind noise. Plus the price is less than most.
