Losing prop blades
Old 06-22-2004, 06:10 AM
Macklin's Avatar
Default Re: Losing prop blades
Throttle Up told me the Bravo's are known for this. I wish the Hydro Q4-X's would have had the excellent cruise speeds of the stock Bravo's.
Macklin is offline
Old 06-22-2004, 06:16 AM
The Menace's Avatar
No, I do not think you would feel it until it actaully seperated. You have a lot of distance between the prop and the hull. Every time you go through a gear you dampen the vibration significantly. That is why I mentioned to check everything else in the line shaft etc. There has to be wear on other components, even though not readily visible.
Picture the relationship of taking a coat hanger and bending it until it heats and breaks. This is what Strip's prop may have experienced. That is why there is a crack in the other blade as well. Once one went there is a significant prop imbalance situation.
I have also experienced props getting out of balance just through running. Not NORMAL running but high HP boats producing excessive load through a lot of torque. Slamming the throttles out of hole may actaully bend a prop blade or blades enough to cause this problem. So it could be the way the boat is operated. It only takes once and the damage may be slow wearing and not show up for hours.
I had to have my drives rebuilt last year. The prop shaft splines were twisted like candy canes. HP + a little flying + high RPM's on re-entry = bent or broken stuff.
The Menace is offline
Old 06-22-2004, 06:57 AM
better take a look at who does your props...also, I WOULD, FOR SURE take that drive down and inspect the gears!...prop imbalance w/o loosing a blade can cause drive failure.
props do not go out of balance unless metal has been added or taken away...however they do fatigue and blades can change individually, most of the time gaining pitch...a drop in RPM is a tell tale sign of this...
audacity is offline
Old 06-22-2004, 07:11 AM
Jassman's Avatar
I've got the opposite proplem, one of my Merc. cleavers is off by 300 rpms, and is noticable getting on plane as well as anything after 3500 rpms, they are going back today.
I Had The Same situation on breaking blades on my Herrings on Radio Active, twice, it can be very dangerous with someone behind you, and thanks for the reminder, I'm still waiting (1 year later) for the replacement props.
Jassman is offline
coolrunning racing
mrv8outboard's Avatar
in one of the pic's it looks like the corner of the lifting strake is in the wake shadow of the prop. this would be an area of little or no water for the prop to grab, this would cause the prop blades to flex from that point out excessively.
when i ran spinnelli props they would break at the root of the blade after 45 min's , went to mazco's props and they are still fine today. just more food for thought.
mrv8outboard is offline
Old 06-22-2004, 07:14 AM
"in one of the pic's it looks like the corner of the lifting strake is in the wake shadow of the prop. this would be an area of little or no water for the prop to grab, this would cause the prop blades to flex from that point out excessively."....incorrect statement
audacity is offline
Old 06-22-2004, 08:21 AM
Official OSO boat whore
Are these stock or have they been thinned?
Cord is offline
Old 06-22-2004, 04:56 PM
HOUSTONPROP's Avatar
it happens ,by looking the props are new. Send it back to Mercury and they will replace it. When we lab finish these props not all but some have casting holes open up. This is caused by air pocket in the casting and when put under tremendous stress it will break.This is called Fatigue.
HOUSTONPROP is offline
Old 06-22-2004, 05:09 PM
Pure Energy's Avatar
Would cavitation cause this? You mention a high X. Doesn't cavitation create heat? Just a thought.
Pure Energy is offline
Old 06-22-2004, 05:15 PM
cavation is like boiling water,yes it creates friction which results in a higher temp.running this prop high in and out of the water will cause the fatigue.Or so to say BLADE FAILURE.
Quick Reply: Losing prop blades
