dyno results
Charter Member #139 /Moderator/Platinum Member
reworked 500 hp
510 ci NA
rpm torque Hp
3600 492 341
4500 578 495
4800 569 520
5600 524 559
still a little carb tweaking to do
510 ci NA
rpm torque Hp
3600 492 341
4500 578 495
4800 569 520
5600 524 559
It looks like 4800 is a nice sweet spot, nice torque. I am at 4800-5000 depending on the temp of air and water, last weekend at 60deg I was at 5000. What are the drives (gear), props? If I went to a labed 23 I would see around 5200 I think and a solid 82 on GPS, I hit 83 at 46deg( not an average day in July
), 40kt tailwind and 2ft chop on lake macatawa in April. I see your Torque drops at 5600, I wonder why (I know, don't say it)
? I have learned so much with mine, I know engines but this boat has helped me understand them and how to set them up, if I could only afford to set them up with 23s, the cover first and the swim platform. Plus I like the fact I can't over rev them, blow a drive or worse....an engine.
Parnell, how are the pics doing, don't want to miss a good deal. I could take yours off the Cig.
![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
![Smilie](/forums/images/smilies/smile.gif)
![Frown](/forums/images/smilies/frown.gif)
![EEK!](/forums/images/smilies/eek.gif)
the motor are going in a cig bullet with beefed up bravos 1.5 ratio
they started as stock 500 hp mercs and one was blown so a cam change a little head work new wpm intake and new demon 850 carbs
I have never seen the hp/tprque curve of stock carbed 500hps if anyone has that I would like to compare
Hp was still building at 5600 I would soon run out of carb at any higher rpm
I am hoping to be in upper 70 with the bullet its pretty heavy
I could run 63 with some tired 365 mags
What ratio are your drives?
