Donzi's New 35ZR (Running)
Registered User
Re: Donzi's New 35ZR (Running)
The 38 is in the mold now, they should have the 38 and the 43 ready for boat show season. The 38 will be a staggered 525 stock and you will be able to upgrade. all the ZRs are built on the same platform as the race boat.
2005 DONZI 35ZR
LOA 35 3 10.74m
BEAM 86 2.59m
DRAFT, DOWN 34 .64m
UP 26 .86m
DEADRISE Variable
FUEL CAP 165 Gal 624.59L
WEIGHT 7,800 3447.30 Kg
MAX HP 1,050
HEADROOM 60 1.52m
FRESH WATER 10 Gal 37.85L
ENGINE OPTIONS
T-496HO B1
T-525EFI B1
35ZR STANDARD EQUIPMENT
12V Accessory Plugs (One in Dash, One in Cabin)
5 Year Transferable Hull Warranty
DC Panel
Air Intakes Recessed
Anchor Locker W/ Molded-In Anchor Storage
Battery Switch W/ Breakers
Battery Setup Dual
Battery Trays Stainless
Beverage Holders Cockpit & Cabin
Bilge Pumps (2)
Bolster Seats, ManualBow & Stern Eyes - Stainless
Bow Rail Stainless Recessed
Cabin Accent Lighting
Cabin Carpet 40 Oz Marine Grade
Cleats Flush Mount Stainless Pull-Up (6)
Coaming Storage W/ cup holders & recessed grab rails
Cockpit Carpet, Snap-In, W/ Custom Etched ZR Logo
Cockpit Cover
Cockpit Courtesy Lights
Cockpit Grab Rails Recessed
Cockpit Liner Fiberglass
Compass
Controls, Livorsi Billet Aluminum Racing
Dash Livorsi Gauges W/ Super Rims & Military-Spec Rocker Switches W/ Detent
Deck Hatches Recessed Custom (2)
Door, Cabin Sliding Plex W/ Lock
Engine Hatch W/ integrated ventilation and sunpad - Electric
Exhaust Thru Transom W/ Mufflers
Fender Cleats (2)
Footrests (2 Fwd, 2 Aft) - Fixed
Fuel Fills Custom (Port & Starboard)
Galley freshwater sink & compact refrigerator
Gunnel Trim, Rigid vinyl w/ insert
Head Compartment, Enclosed, W/ porta-pottie, freshwater sink and shower.
35ZR STANDARDS & OPTIONS, CONTD
Headliner Premium Suspended
Horn, Recessed Electric
Hull & Deck Joint Chemically bonded and glassed
Ignition - Keyless
Ignition Safety Switch
Indicators Mechanical Trim & Drive
In-Dash Cooler W/ Drain
K-Planes 280-Series
Laminate Light Weight Kevlar Hull & Deck, Vacuum-Infused Transom & Hull Coring
Nav Lights Hi-Intensity LED, Flush Lenses
Navigation System 5 Color GPS Chart Plotter (Lowrance Globalmap 3300C)
Props- Stainless
Rear Bench Seat W/ Storage & Insulated Cooler Bin
Speedo GPS
Steering Full Hydraulic Latham
Steps, Molded Foredeck Access (in Port Helm)
Stereo Premium Sony AM/FM/CD W/ 6 Speakers
Stringer System Glass Encapsulated Composite W/ Full-Length Keel Stringer
Swim Ladder
Tie Bar External
Transom Shower
V-Berth W/ Storage
Windscreen Fiberglass W/ Plex Venturi
Z-Tech Hull Design Race Proven
OPTIONAL EQUIPMENT:
Air Conditioning
Anchor Lightweight Aluminum
Battery Charger
Bolster Seats, Electric Port & Stbd Helm
Cabin Lightweight Poker Run Version
Carbon Monoxide Detector (Std W/ Generator)
Color-Matched Engine Compartment
Compass, Digital
Convenience Pkg (Shore Power, Battery Charger, AC Panel)
Dash Panels Custom Painted W/ Color-Matched Gauge Pods
Exhaust, Quick & Quiet Plus W/ Mufflers
Fume Detector
Generator
2005 DONZI 35ZR
LOA 35 3 10.74m
BEAM 86 2.59m
DRAFT, DOWN 34 .64m
UP 26 .86m
DEADRISE Variable
MAX HP 1,050
HEADROOM 60 1.52m
ENGINE OPTIONS
T-496HO B1
T-525EFI B1
DC Panel
Battery Setup Dual
Bilge Pumps (2)
Cockpit Cover
Compass
Fender Cleats (2)
Ignition - Keyless
K-Planes 280-Series
Props- Stainless
Speedo GPS
Swim Ladder
Tie Bar External
Transom Shower
V-Berth W/ Storage
OPTIONAL EQUIPMENT:
Air Conditioning
Battery Charger
Compass, Digital
Fume Detector
Generator
'bout 180K I bet with H.O.'s and little else for options
I see it's 35'3" LOA and 7800 lbs.
800 lbs lighter than the Formula 353
I'll spot you 4-5 MPH for the 800 lbs...but 10 MPH? Must be one hell of an aggressively stepped bottom / high X.
Who will be the first to roll one?
I love the ZR raceboats - they are totally bad ass. But I said this once and I'll say it again. The running hull surface on that 35 ZR makes the beak on a 35 Fountain look small. No wonder it weighs so little. I can't wait to see the 38's.
I saw a 35 at the Annapolis boat show. Looked very nice. It's a low deck so head room is lacking, but would make a sweet poker runner!
