the new BAD BOY 38 canopy !!! >
Old 01-04-2005, 11:49 PM
Registered User
Papache's Avatar
Default Re: the new BAD BOY 38 canopy !!!
Rose bud is that carbin fiber or sglass combo.Is it vaccummed bagged .What are the stringers made of. Post some pic of the build process
Papache is offline
Old 01-05-2005, 07:10 AM
cashbrain05
When I was at the SBI race in NOLA a few years back...the first boat was there and it was awesome !! and those guys worked their tail off on that weekend dialing it in. Nice to see a company building boats like these...
Now..about that name..I know,something with an Indian sound to it
Old 01-05-2005, 09:05 AM
Registered User
Wazzup Racing's Avatar
I ran against that boat all season, no one has had a better view of that boat running than me." Rock solid." should be the name of the first one. Good luck Tony.
Wazzup Racing is offline
Old 01-05-2005, 11:45 AM
BODYSHOT1's Avatar
Awesome Tony!
Best of Luck to You...
Marty
BODYSHOT1 is offline
Old 01-05-2005, 12:47 PM
Who is racing a Bad Boy in 2005?
Ben@SRP is offline
Old 01-05-2005, 09:38 PM
[/SIZE]We are all very excited!
P apache, the canopy-kinda sorta but not really. Its Tonys own design. If you look, you will notice the rear sides are different, I thought the same thing as well. The boats are built with Kevlar, E glass, carbon capped stringers 100% vynalester hand laid, all cored and vacuum bagged. After extensive research Tony told me that the grid structure used only in the engine compartment is made of wood and glass. He found that the wood had better strength then any core stringers available; The wood w/ glass has better strength when a hole would be drilled for motor mounts or rigging, the holes will not widen or get larger over time. The 1st 38 that ran all the races has no cracks, and I have looked, all over and I can't find them ESP after just racing. I hope the Bad Boy Boats will be racing all over!
Bob, Hi! Shhh we're supposed to keep that Aronow stuff under wraps! But yes, we are mixing up many things for the OSO community! I have a few custom gas r/c boats we are rigging, they are fun.
Best to all
Christian
TOASTY is offline
Old 01-05-2005, 10:15 PM
knotpropr
Typically, when core is done properly, it is the ultimate material, the stringers are strong by design, not the material used inside.
Old 01-05-2005, 10:51 PM
Hot Duck's Avatar
That hull looks a lot like the 39' Kryptonite hull. The Kryptonite absolutely hauls a** so I have no doubt that this new Bad Boy will do the same! The top picture here is the Bad Boy and the bottom two are the Kryptonite.
Attached Thumbnails the new BAD BOY 38 canopy !!!-1-bad-boy.jpg   the new BAD BOY 38 canopy !!!-1-kryptonite.jpg   the new BAD BOY 38 canopy !!!-3.jpg
Hot Duck is offline
Old 01-06-2005, 10:29 PM
Registered User
Papache's Avatar
We are still wating for the pics of the build process. also pic of the shop and the prep work.
Papache is offline
Old 01-06-2005, 11:27 PM
DannyD's Avatar
Good Luck Tony! The boats are looking great!
DannyD is offline
Quick Reply: the new BAD BOY 38 canopy !!!
