Hot Tops Marine drop out bolsters
JC Performance Engines
These are made by Don Frost.
They're about 1100/ea, but look real nice w/ clean lines.
Titan, the seats need to be drop out/stand ups.
Can they build them?
speel chekk this fokker!
doh i totally forgot abotu don frost!!!!
u hear he does good work
Pardon me, while I whip this out!
I had a pair of these in my first race boat. The first race I bent the drivers bolster approx 3 inches off center. If you plan on rough water I would ask them to cross brace it. Also.....insptech is correct....I am a fat ass and with my lifeline on I still fit comfortably. The vinyl held up over 2 race seasons and none of the stiching came loose. If you are on a budget, these are a nice bolster.
Thunder... I'll get it for you tomorrow.
BTW, my bud w/ the magnum just placed his order w/ frost.
I have had two sets from them. They are great for the money. I had one set made to the spec I wanted. He needed to know the inside width of your cockpit, your height, and the freeboard height in the boat. You may end up needing to adjust the stand up and sit down position with a steering wheel hub adapter for adjustment. Make sure you stand in the seat, sit down in it, and exit the seat location in the location you think you want it in before you mount it.
Good Luck
E.S.
Good Luck
E.S.
Originally Posted by insptech
Just got some this month for the Formula. The vinyl and stitching are real nice and the place is good to deal with.
2 issues: They are very wide, I have a 40" waist (I know, I'm back at the gym
) and I have about 3 inches clearance in them. If you order you might want to ask that they be made narrower to hold better. I like to kind of push into a bolster for rough water.
The other thing is the latches for the bottom-basically 2 small pieces of tube that rotate to lock the seat up-they seem sturdy but a little primitive.
The welding on the frames is nice and the mounts are full length and seem real study.
Overall since they are about 1/2 what the nearest competitor wants they are a pretty good value.
BTW ask for the OSO discount-should save you a little scratch![Cool](/forums/images/smilies/cool.gif)
