What's the best oil change setup ?
Re: What's the best oil change setup ?
Hey Strip ....also why pump it ? .. I was looking at the kits....60.00 ..for a fitting and a piece of hose ..... Is that a cap on the end ?
Originally Posted by offthefront
Mag .. you make that ?
The pump is a teel you can get it from Granger.You can hook up a water hose to it also.run dry and come with a rebuild kit.
Its sucking it out . It will suck out 10q in less than a Minuit.. I use a 5 gallon bucket ,hook up the clips ,flip the switch and The cap in on the out put some not to drop any.I just wire tie the hose that on the motor by the sea strainer and use the quick connects .I can change both motors in about 30min. Takes longer pouring the oil in it. and no mess.
Shop around on the fitting with the hose .I have found them for around 15.00.Been awhile though,I changed out the hose to the blue areoquip 3/8 fuel hose for looks .The quick connect I get it at a hydraulic hose place for about 10.00 for both in steel . the brass was high.
I can take better pictures since the motors are out if anybody wants???
Why pump it out ? Gives me more time to drink beer
Rob
Rob
