Help No Oil Pressure At Sender >
Old 04-11-2005, 04:31 PM
plumbers crack's Avatar
Question Help No Oil Pressure At Sender
I started my motor and couldnt get oil pressure at the sender above oil filter adapter stock location.I then replaced the sender and took the old one and installed into relocated oil filter on the back of the head and started the motor and the guage is pretty well pinned on 80 lbs.Bought another guage and it still read 80lbs.WTF?
The motor is not a gen 6 block,Do I have the lines reversed at the oil filter?
I even removed the sender and no oil came out but the passage is clear and you can see oil inside.
Also doesnt seem that the oil is getting up to the top of the motor either.Any Ideas?
plumbers crack is offline
Old 04-11-2005, 06:58 PM
Received 1,894 Likes on 952 Posts
Default Re: Help No Oil Pressure At Sender
Did you do or change something before this started to happen????
Griff is offline
Old 04-11-2005, 08:44 PM
Talking Re: Help No Oil Pressure At Sender
I never ran this motor,but I did change the oil cooler and filter housing.I took a photo of the old set up and it looks like I have the oil lines reversed at the filter.That is why my pressure is so high it wont flow backwards from the filter>Just a guess Ill try to look tomorrow.
Old 04-12-2005, 06:17 AM
PatriYacht's Avatar
Do you have the kind of adapter that goes in place of spin on oil filter? If so the oil goes out the fitting on the side and back to the engine through the fitting in the center.
PatriYacht is offline
Old 04-12-2005, 06:05 PM
Good answer Patriyacht,switched the lines today problem solved! I could have kept it a secret but Nahhhh.
Clue #1 high oil pressure 80 lbs
Clue # 2 No oil pumping up to valvetrain
Clue #3 Im left handed and no oil coming out of sender port.
I asked 2 very good engine builders and they were clueless,but its spring and they are overworked.
Thanks for the reply Brian
Old 04-13-2005, 07:55 AM
PatriYacht's Avatar
Your welcome. Hope you didn't leave it running long enough to damage anything.
Old 04-13-2005, 07:09 PM
Its all good just ran for a minute,the lower end is immersed in oil so should be fine.I cranked it over to check wiring to guages(new Boat)and caught the problem before starting.I will post pictures of the new machine soon.
SCANDINAVIAN
0
06-10-2007 03:39 PM
Revd Up
6
07-06-2006 11:32 PM
DORaymond
5
06-07-2005 11:10 PM
Danny_Ocean
4
04-05-2004 10:47 PM
Waterfoul
12
06-16-2003 06:47 PM
Quick Reply: Help No Oil Pressure At Sender
