New U-bolts Ready To Ship
B-MAX REPAIR
The New U-bolts Are Finished And Ready To Ship. There Made Of An 17-4 Ph. They Are thread Ground And Come With 2 Monel Nuts. Oem U-bolts Tested At 8300 Lbs Before Stretching Or Stripping Off The Nut. These U-bolts Went To 15,000 Lbs. The Install Will Be Torque At 55 Lbs. You Must Use A Good Lube On The Threads So You Don't Gull The Nut To The U-bolt When Tightening. This Will Solve The Problem That Heavy Or Bigger Hp Boats Are Having. So If You Send Me Your Gimbel Ring To Rebuild You Do Need These U-bolts!!! Cost Will Be $55.00 Each.
Ron Bender 216-390-1330 :d
CPPerformance
New Products and Member Discounts
0
02-20-2007 01:03 PM
thisistank
03-26-2005 09:47 PM
