Whipple Stage II Kit for the 496HO (non supercharged)
Going from a simple Whipple re-program kit for $795 for 35 hp, to a $2500 Raylar heads only, not including everything else that goes along with it for 50 hp isn't even comparable... Installing the Raylar kit is flat out a bunch of work. That's a big step-up over re-programming an ecm.
If the Whipple kit actually makes 35 hp and the same torque, what's the point of just Raylar heads alone for only another 15 hp at 4 to 5 times the cost.
Dustin, please step in here...
Originally Posted by Harper220
They're selling the kit to make money. Whether it performs like their claims is another story. I really don't think you'd get a guarantee in speed from them. 35 hp on twins might equate to 2-3 mph. gain. Make some calls and post back.
![Mad](/forums/images/smilies/mad.gif)
Originally Posted by Highmark
If not then I guess that would be a good indication of what gains are to be had.
I have a 33OUTLAW and I had the stage 2 done I did see honest 3 mph .Im now running Whipple Sc 7lbs boost 356 hrs had her out last week .Burned up last years fuel.I can tell you one thing Dustin Whipple knows 496s the first 2years out they ran ritch Dustin cleaned that up for Mercury. Dustin spected out my new 800sci 496s should be in boat first week of may
I would have to believe that heads would increase HP and Torque a great deal more than just a simple ecm re-program, and my point also was so that you don't have to run super but can stick w/ 87
Originally Posted by mike0311
Good point! I remember reading that Arizona had a similar kit and it wasn't positive. The thing that I would have a hard time believing is that a reputable company like Whipple would offer it if it was at the least parcially correct. There has to be someone out there that has tried it from Whipple.
Guys, you have to ask WHERE is this 35 hp increase??? Is it at 3000 rpm? is it at 4000 rpm? If the increase isn't at or around 5000 rpm, don't expect any speed gain. I have the AZS&M kit on my HP500EFI , with the larger throttle body, intake ported to match, and the computer recal, I noticed more snap at mid range, but no speed increase.
These manufactures that claim 35 hp increase, may be referrin to a dyno sheet at 3500 rpm. " Hey look there is an increase here!! Great!" But at 3500 rpm, not top speed increase.
Just FYI.
Just FYI.
here are the numbers.
496hoBravo3 duel counter rotating props. Inner prop 4blade 22.5 pitch. Outer prop 3blade 22.5 pitch. 103gallons of fuel 6people aboard 58 mph @4900rpms. Planes in 3secs.
half tank 4 aboard 63mph 5250rpms.
