Harmonic balancer & pulley question
I need to change from a two groove crank pulley to a three groove. So in doing this yesterday, one of the corroded allen head bolts stripped out and I cant get a drill to where it is. Can I pull the harmonic balancer and pully at the same time with a gear puller? I would think I can but not sure. Thanks
Dave
Dave
Re: Harmonic balancer & pulley question
usuualy you cant get the balance bolt through the pulley and in that case no you cant. But if the big blancer bolt does come out then no problem you just mau need to get some longer bolts for the puller to clear the pulley.
Dave
Dave
East Coast B
2
06-13-2005 05:00 PM
