HELP? I cant get the Power Steerring Bled
Re: HELP? I cant get the Power Steerring Bled
Originally Posted by Linster
I've never cracked any lines or fittings, all I did was start the engine & turn the wheel back and fourth until it cleared itself. I had someone helping me to keep the pump full.
With the engine running, can you push the drive(s) to either side? IMCO says that if the drive moves more than 1/2", that there is air in the system. If you have air in the rams it should be obvious.
Rob
Tried bleeding again and nothing. I took the pump off cking it the valve looks ok. It doesn't act like its air . The is no power assist at all. Like its not pumping . If there is air in it would it at least have some assist??
Hi Rob,
Your pump is different than mine. I'm running the automotive style that mount up high on my motors, with their own internal reservour. I have an external reservour that feeds the top of them.
Last winter, I added hydraulic quick disconnects to make pulling motors less messy. I had a problem with one of my pumps not pumping, and it turned out that the size of the fittings from the external reservour to the top caps of the pumps were too small, not supplying enough fluid to operate the pump. My symptom (other than stiff steering with just that motor running) was the external reservour would back up to the point of overflowing.
Is it possible that you have a restriction from your reservour to the pump?
I have dug into one of my old pumps to see how she ticks. There's a rotor inside with a series of steel vanes that act as an impellor, some valving, not much else.
Does yours come apart? Might be time to dissect it.
Good luck,
Brian
Good luck,
Brian
p4-33, I can agree with what you said.
The common problem in a dual system is the pump farthest away from the resivior is also the last to get any oil. The best thing to do is run a separat an LARGE hose to each pump. Do not tee into the bottom of the resivior. You need another hole.
The pump farthest from the resivior runs out of oil and since it cannot get back to the pump from the resivior lines fast enough it overflows. Then the steering will not work. The pump will also aeriate the oil with bubbles that get sucked throughout the entire system.
I had fought this problem for a season before finally fixing it to working fine.
Hope this gives you some ideas to your problem.
47 Lightning SE
47 Lightning SE
Rob
Brian the reservoir is the black plastic tank and sits above the pump and has a 1/2 rubber hose feeding the pump. I looked in the reservoir and it was clean no metal.
I took the filter apart again and blew thru it with my mouth .Its a machine marine filter with a wire mesh type screen filter . I could blow thru it . I am real sure its not the prob.It was clean when I started and when I looked at it again there was nothing in it .
There is a snap ring on the back of the pump .It will mess it up when i take it out. If I buy another pump I will disect it to see how it works . Dealer cost on the pump is 308.00 so I kinda want to make sure its the pump.
Pedro At Machine Marine told me the pump is the same as on a 2003 Chevy truck .Nope not even close
Does anybody know IF the system has air in it will it feel like it doesn't have power steering??.like its in manual override ???
I am thinking its a restriction or the pump is not pumping .
When I revved up the motor it did not get easier.
The steering rams will not fully contract or extend I bled it the last time.I think the B Max drive changes the mounting point father back than the bravo . So I don't have full turning capability
The drives will not move with the steering arms hooked up.
I solved this problem last spring. My quick disconnects supplying the pumps were undersized - 1/4" ID. I bumped them up to 3/8" and she works great now. Sure was acting like Rob's problem when running the one motor by itself.
Thanks for the input,
Brian
Rob
Another thing when we first started last night my buddy started turning the wheel just for the h e ll of it, before we did anything and the wheel turned freely for a few turns .Motor not running, then it got hard . I figured it might of been a air pocket?
I Just talked to a buddy He said it sounds like that its the same as the one on his Grand National Buick , but the Buick one turns different direction. he said he has taken the vanes out of a camaro one and used them in the Buick one .
He seems to remember the vanes haven a pitch in them thinking it will only pump turning in one direction[rotation]
This pump has to be a GM pump
Air in the pump circuit can cause what you're seeing, no power assist. If you have air in the ram circuit, the pump will still drive it, but it will feel spongy or jerky. With enough air in the rams, you can push the drives by hand, and they will spring back. Sounds like this isn't your case.
Best of luck,
Brian
How big is your reservour bottle? On a 38' boat, there has to be a couple of gallons of fluid total in the system - pump, lines, helm, bottle. When you bled it initially this year, how much fluid did you have to add before the reservour bottle held it's level?
Are we having fun yet?
Brian
