Cig pulls left
Originally Posted by Von Bongo
Update.
Problem gone, went through the proceedure from when I had new hyd steering to get air out and no more pulling.
Someone is going to have to tell me how "Toe" {In or out} Could make a boat pull one way....Think about it ......
A to Z
Originally Posted by birdog
Glad you got it done !
if the toe didn't match on both drives (in or out) it would make it pull or not track straight....
A to Z
I can see it being a handful to drive....But not a "Pull" one way
They would just be fighting each other....No ?
if the starboard drive was straight ( 0 toe) and the port was toed out it would want to steer to port, not cleanly, but it would wander that way, and if it was toed in, it would wander to the starboard side.... they would fight each other if they were equally, but opposite, toed in or out....
Yea...Thats my point....One would not be straight. They would both be out {Or in} equal amounts...See what I'm thinking ?
I could be wrong tho....It happened once before....
Ginger or Mary Ann?
Not like one drive is straight and the other is turned and you are still going straight. You will turn the wheel alittle and split the difference when running to go straight. so both in or out the same amount. Only thing outta wack then is the spoke postions on the steering wheel.
elroy521
8
09-05-2008 08:19 AM
