Cracked Trim Pump Reservoir >
Old 04-27-2005, 08:43 PM
Default Cracked Trim Pump Reservoir
I have a cracked trim pump reservoir, 1989 vintage, any thoughts on where to find one??
TomR is offline
Old 04-27-2005, 08:47 PM
NJSONIC's Avatar
Default Re: Cracked Trim Pump Reservoir
Happened on our old boat. You can get a new one from Mercury it comes as a kit-reservoir and seal. It is a 15min job to replace(once you can get to the pump). You just have to get to the bottom of the reservoir.
NJSONIC is offline
Old 04-27-2005, 09:15 PM
KSFLYER1's Avatar
OOps, just reread your post. I just ordered a reservoir for my outdrive today. It was $70.
KSFLYER1 is offline
Old 04-28-2005, 08:15 PM
Offshoreonly Advertiser
Mbam's Avatar
Bad news, single screw version is NLA from Merc. The fix from them is a new pump body and reservoir that attaches with 4 screws. We can sell the new pump complete for not much more than the kit.
There are a couple of billet reservoirs around.
Mbam is offline
Old 04-28-2005, 08:25 PM
formula31's Avatar
Ive had real good luck fixing them with Marine GOOP. You have to take the reservour off, clean it real real good and seal it from the outside with the goop. You may have to do each plane (side)so it doesnt run off. Ive done mine this way and they havent leaked in years.
formula31 is offline
Old 04-28-2005, 08:41 PM
BRUCE SEROFF's Avatar
Tom..I might be able to hook you up
BRUCE SEROFF is offline
Old 04-28-2005, 09:24 PM
hillbilly24's Avatar
You can get the single screw version from volvo penta. Same part and its still available through them
hillbilly24 is offline
Old 04-28-2005, 10:59 PM
Thanks Guys,
I got an email from another board member, Aftermarket1, he had them available. Apparently Merc no longer offers the old type but there are a couple of aftermarket sources for them! $29.95
TomR is offline
Old 04-29-2005, 12:19 AM
Rob
Strip Poker 388's Avatar
Originally Posted by TomR
Thanks Guys,
Sean is a good guy . he will hook ya up
Strip Poker 388 is offline
Old 04-29-2005, 06:13 AM
I had never talked to him before, but he seemed to be a good guy! Thanks for the reference Strip.
TomR is offline
BillR
04-25-2006 08:32 AM
ratman
01-26-2006 07:48 PM
SeaWeasel
2
07-21-2005 04:29 PM
guillermof
4
09-13-2003 11:28 AM
Quick Reply: Cracked Trim Pump Reservoir
