Carpet glue
Does anyone have any insight on what type of glue to use to fasten new marine grade carpet to the sides of an older Outlaw cockpit . I considering using Weldwood waterproof contact cement. Thank You
3M super 77 or even better ultra 96. If you use either one make sure and use it right or it won't hold. Spray it on both surfaces and let it tach for a couple minuits then put em together and it aint commin off.
I saw the 3M spray product at the adult toy store " Home Depot " but had concerns about what it was recomended for and the waterproof on the contact cement cought my eye. Thank You for your input I will surely take it into consideration
The Snap On tool truck is my adult toy store of choice, Home Depots allright though
I did a boat a few years back with Weldwood contact cement, it worked well. just make sure to do it outside, the fumes will kill ya in a garage
Steve
![EEK!](/forums/images/smilies/eek.gif)
The water clean up plain old cheep carpet glue works good not the outdoor more expensive glue gas will cut it loose the cheaper glue takes a long time to dry but once it dries it is there
Just recently tried the 3m spray on a neighbors boat,, the carpet didn't stick very well at all,,, ended up peeling it back and using water proof contact cement from home depot..
