Roller lifters input
#51
Im going to use the Jesel .903's or if that doesnt work out,then I'm gon a use the Crower.903's.
Hopefully I can find some Jesel's for a somewhat good price...LOL
#52
Charter Member #40
KE does a spray bar for the lifter valley that sprays on the lobes/lifters. I went to them three yerars ago and lifter failures went away. Even with Big Chief offset lifter. I can get over 100 hours on a set with 210 at the seat and .678 lift/254/262 at .050.
#53
At what HP level are you guys playing at? I guess I am asking at what point does one need to be concerned with going to high end lifters? Is it more on the lift you are running or RPM or spring pressure. I have 300hrs on the crane lifters in the motors I am freshening now, yes solid set up, however low lift by comparison. I am getting different suggestions as well some say go hydraulic set it and forget it but I really don't mind setting lash every now and then.
If you were >700hp >.650 lift natural asp. is there any need to spend the coin on high end lifters?
Russ
Russ
#54
#55
Originally Posted by SQUISHFACTOR
Comp Cams also makes a lifter bore grooving tool that slots the lifter bore and provides extar oiling to the camshaft. Not quite as good as the hippo option from crower but it does work.
I believe they have the HPPO option too.
#56
Originally Posted by Mr Gadgets
I am going to try the Schubeck Roller X's and see what happens. Here is another lifter available. They created these after using the Jessels for years. Not sure how well they work. And they too are very proud of them..
http://www.lsmeng.com/Lifters.html
I had them put bushing in my block back in 99 and was real happy with there quality of work. The owner's son is somewhat opinionated, but they do a nice job.
Dick
Dick
#57
Originally Posted by NOBODY
I have talked to a couple of pro mod guys running the Roller X's with good luck. Hope you have the same results.
#58
Originally Posted by Johnny DCB
Do you have to buy them direct or from where?Any idea what the price is and do they have a .903 lifter also?
Yes they have .903
I personally have never used them, but they have a great design and are lightweight.
#59
Try Schubeckracing.com
Yes they have .903
Yes they have .903
#60
Charter Member #40
Johhny, I also went to valve spring sprayers and it did a nice job in extending the life of my Jesel rockers. I spoke with a co that did some testing with the Schubeck's a couple years ago and all was fine providing you didn't let the spring pressure get to low allowing lifter float as apparently the coating on the face of the lifter can chip and all heck breaks loose....so i was told. In drag race where they stay on top of spring pressures they do a very good job....so they said.
