Valve guide clearance...Is there a..
Consensus on how much? I am having my heads tuned up and my new head man thinks 4 thousands is too much.
He suggests 1.5 - 2 thousands of an inch
For those of you machinists and engine builders, what would you have in your marine application?
Also going to T&D shaft rockers and Inconel valves. Valves are 2.45 intake and 1.94 exhaust.
I agree with your head man that .004" is too much. Can't argue running .0015 to .002" regardless of guide material (you don't say whether they're bronze,etc). Some folks will aim for .001 to .0025" but your guy seems to be right in the ballpark. Just one person's opinion...
Originally Posted by Lmarth
Just noticed the size of your valves. I'm curious about engine size, comp. ratio, induction,etc. Just curious...
605 inches, 10:1 C/R Naturally aspirated (carb)
Have single 1250 dominators now. Considering using a tunnel ram and want to keep the midrange good. The tunnel ram is set up for dominators too but I think two small dominators (750s) may be better for my RPM range which is 6-6500rpms.
Any feelings there?
That's a lot of motor...and a lot of rpms. It wouldn't be appropriate to comment since the induction system, heads, cam,etc. need to be considered as a package. Cranks aren't glamorous things, but are critical with big inch, big power motors. You almost never see them mentioned when talking about motor buildups. I don't think you can go wrong with Lunati, Callies,etc. Twisted or non-twisted.
Just remember most shops do NOT have a dial bore gage to be able to measure the guild clearance correctly . They are expensive . And most want go to the trouble to measure them .Most I have watched broach them and they say they know what .002 -.0025 feel like
.they may be close ?some will just hone them and get them closer.
I would think a alumium head will be differant??
I set my exhaust guilds at .0025-.0027 on my blower motors .We use manganese bronze guilds and we used the US seals blue seal.I have done this before and it does not smoke on start up.This is just my experance .ya know I am no head guy
But I did stay in a Holiday Inn last night
Goodluck
Rob
![EEK!](/forums/images/smilies/eek.gif)
![Drink](/forums/images/smilies/drink.gif)
![Evil](/forums/images/smilies/evilB.gif)
Goodluck
Rob
Goodluck
Rob
Goodluck
Rob
What about just measuring the "rock" of the valve just off the seat with a dial indicator?
BTW, I have the bore gauges but most ive seen just check how much rock the valve has.
Originally Posted by MESABALANCING
STRIP if the guy doesn't have a sunnen bore gauge he can use a plug gauge it's cheap and effective the clearance is about right I run .001 on the intake and .0015 on the exhaust with no ring on the exhaust seal and they don't smoke either you can get the plug gauges from ENCO MANUFACTURING or J&L shop supplies .
Laz you run your exhaust that tight????
Rob
As a Quality Inspector, Calibration Tech, and an excellent machinist, if the machine shop does not have a proper bore gage there is no guarantee the job will be right by just using pin gages. Most shops don't want to spend the money to calibrate their tools. Pin gages wear quickly if not treated with utmost care.
Ever see what happens when one get stuck in a hole? Some people will take pliers, or worse, Vise Grips and pull it out.![EEK!](/forums/images/smilies/eek.gif)
And remember this, pin gages are usually purchased in what's called "Minus" sizes. That means that a .500 gage pin is actually .4998. A .500 pin will not fit into a .500 hole. That's a press fit.
So, if a "machinist" is trying to measure a .002 to .0025 hole with pins he'll never get it right. He could wind up being undersized or over.
