Roller Rocker tips on 502 GVI
Re: Roller Rocker tips on 502 GVI
Stock valve covers will fit. You just need to grind off the oil drip tabs on the inside of the stock valve covers.
You also may need to grind off the corners (1/8") on the rocker arms on #1 and #8 intakes. This is what Merc does on all blue engines.
