Adjusting throttle cables >
Old 05-07-2005, 10:34 PM
gripit's Avatar
Default Adjusting throttle cables
I have Keikheiffer throttle on a 454 trs setup. After pushing the throttles to 3500 rpm I back them backdown to the lowest setting but the rpm are still a little high like 1200. I can manually push the throlltle housing forward and the throttle goes to its lowest setting and idles properly. So I think my throttle housings or cables need some adjustment. Does anybody know how to do this? Thanks
gripit is offline
Old 05-08-2005, 02:22 PM
tmdog's Avatar
Default Re: Adjusting throttle cables
How about a stronger throttle return spring?
tmdog is offline
Old 05-09-2005, 05:27 AM
gripit's Avatar
Where would I find that on the cables or on the carb?
gripit is offline
Old 05-09-2005, 11:13 AM
hillbilly24's Avatar
take the cable off the catb and turn the end until it lines up perfectly with the stud or ball. Then turn it in 3 turns and your in buisness. you should have a little tension on it and that works alot better then a stiffer spring. Cables will stretch over a period of time and need to be adjusted periodically.
hillbilly24 is offline
Old 05-09-2005, 11:18 AM
gripit's Avatar
Question Re: Adjusting throttle cables
Ok, let me see if i get this straight.
You want me to take the cable off of the carb. Turn the end of the cable. By twisting the cable or??? I'm not sure what you mean. Please be more specific.
gripit is offline
Old 05-09-2005, 01:27 PM
RedDog382's Avatar
You should see a little stop nut at the cable end where it threads on the red connector. Remove the red connector from the throttle arm, loosen the stop nut and turn the connector out or counterclockwise. Re-tighten the stop nut and reattach to the throttle arm.
RedDog382 is offline
Old 05-09-2005, 01:49 PM
gripit's Avatar
How many times should I turn the nut? 3x like Hillbilly24 said?
gripit is offline
Old 05-09-2005, 03:57 PM
CIG3's Avatar
That should be fine to start. You may need to experiment. Also make sure all the connections on the engine brackets are snug. Not too tight as things will bind up.
CIG3 is offline
Old 05-09-2005, 08:00 PM
gripit's Avatar
It adjustments worked great on both engines. Then the port engine had high rpms again around 1500 only after I shifted from forward to neutral and reverse then back into forward during my parking maneuver. Inotherwords, on my test run both engines returned to idle perfectly just throttleing up and down many times. Only after shifting gears, the port engine would not return to idle hung around 1500rpm. What do you think I should do now? Should I continue to counter clockwise adjust the cable or some kind of other adjustment is in order???
gripit is offline
Old 05-09-2005, 08:23 PM
try giving it a little more tension with the cable before you replace the spring. The stiffer the spring the more jumpy the throttle will get. It will require more initial force to move the throttle wich makes fine adjustment hard. If this still doesnt work, try and back it down manually at the carb again if yo still have slack tighten it more, if not you need to adjust the carb.
Quick Reply: Adjusting throttle cables
