Timing chain and gears
I am building 2 509 Gen 6 motors. What is the favorite timing chain and gear set?? I was thinking about the Cloyes Hex-Adjust double roller.
Anybody feel differently ??
Dave
Dave
I have installed a Cloyes hex adjust double roller chain in my gen 6 502 block.The timing cover is an Imco cast aluminum. I used a gen 4 style cam with a thrust button.I cannot say if the same chain will work with gen 6 style cam.
Cloyes actually makes the Hex Adjust for a GenVI. I had one in my motor but took it out after more than one of my fellow race motor builders expressed concern!
But it is available and it will fit under your timing cover on the snout of a GenVI cam (provided that is what you have).
The GenVI design that utilizes the thrust plate is a far better design than using a thrust button as was used in the GEN IV & V motors. In fact, Merc had used the thrust plate design in the later versions of the GenV HP 500's. It must have been a custom ground cam because the older style timing gears worked!!
I recently saw the cloyes gen 6 hex adjust at tyler crockets shop,the only thing is i think it was a big single roller like the stock one,not a double roller,Smitty
tomas_wallin
7
05-26-2005 02:06 AM
