Best distributor that fits Dart tunnel ram?
I can install the Merc distributor body if I remove the cap, but there's no room for the cap. Looks like I need a distributor with a small diameter cap. What are you guys using?
Re: Best distributor that fits Dart tunnel ram?
Should have said the intake has been converted to port injection, so the distributor has to be compatible with EFI. I have a MEFI3 distributor I'm going to try next. Is the MEFI4 distributor the same?
This is a MEFI4 distributor from a 2002 HP500EFI. Other than the blue color it looks a lot like the red MEFI3 distributor from a 1996 502MPI. Both caps look smaller than what I tried first. I can't use a crank trigger because of pulley alignment issues. I'll make this work if I have to alter the intake to do it.
