Bravo Gimbal Tricks
Bravo Gimbal Tricks
First, what is the stuff to retain the bushings in gimbal ring and gimbal housing? I'm thinking red locktite (bushing retaining type). OEM stuff was like a grey epoxy, tough stuff.
Second, this is '89 Bravo.
Thinking of making a bushing to bush from roller bearing OD in lower gimbal housing, to later, '96-'98, bushing OD and use the later setup. (OE roller bearing in sandy environment???!!) Pin is the same, I believe, hard anodized aluminum, .875 OD. Anybody been there?
Re: Bravo Gimbal Tricks
Just after my first post, I went out and 'routered' the transom wood and fiberglass that was inthe way of putting wrench on upper pivot pin nut, from inside of transom. And just as I had thought, I DO NOT have a 'roller bearing' at lower pivot pin. It's a white fiberglass-looking BUSHING. This is supposedly only on '96 - '98, and only on 'Magnum'. I had a 330 so I am guessing I have the 'standard' gimbal.
https://www.mercruiserparts.com/Show...STEERING+LEVER
Last weekend, I had pulled everything apart that I could, (except for upper pin), and the lower bushing DIDN'T look like a roller bearing; but with bellhousing and gimbal still in the way and lower pin out, I couldn't be sure.
I called BAM, or mercruiserparts.com, to try to find out what the deal was with the variations, and Gary told me I was wrong, that it WAS a roller bearing. I have an '89 Bravo; it's all original, and I bought it new.
WTF?
WTF?
