Help, what carb would you pick?
If the price is right, would you be interested in selling your BG 750? Only need one
Official OSO boat whore
Originally Posted by Whiteknuckle
Cord
The Holley Tech guy on their help line told me a rule of thumb is about 15% additional CFM required for Marine applications when using the formula that Rookie mentioned. From what I have seen on the dyno, that makes sense.
Finally, got somebody to confirm my theory. Thanks!
So that means that my new carb is to small
I just bought a Edelbrock 750cfm for my (454*5100/3456)x1.15=770cfm...
An 800 would probably be more appropriate then
![Blaster](/forums/images/smilies/blaster.gif)
![Mad](/forums/images/smilies/mad.gif)
Off the Radar
1 Post
One point missed on the formula, you do not have a 100% efficient engine. You missed was deducting the efficiency factor. The average engine is less than 90%. Even top Nascar engine builders can not get 100%.
454 x 5300 / 3456 x 90%= 626. I always moved up some as did Cord. Any move up here is a guess. I would use a 750 Holley Double pump. 626 x 1.15=720.
Thats right! Then I'm still ok with my 750...
Im spinning mine at 5400 with a 780 and a single plane and the vacuum is near zero. Ive always been led to believe that if you undersize the carb the wot vacuum reading will be higher.
