Limit and Trim Switch Install >
Old 05-12-2005, 03:03 PM
Default Limit and Trim Switch Install
Can someone please tell the best way to replace the trim limit and the trim sender on a bravo 1 drive.Possibly without removing the gimbal housing.
JIMB is offline
Old 05-12-2005, 03:15 PM
Location: Omaha, Nebraska. Boat on the Mighty Mo! Longest river in the USA!
Default Re: Limit and Trim Switch Install
I have done it several times Bravo and Alpha. You still need to take the hinge pins out and lower the housing. That will give you enough room to put a swivel on an extension. I taped the bolt into the socket when I reinstalled it.
Nothing to it, if you have small hands
1BIGJIM is offline
Old 05-12-2005, 05:34 PM
hillbilly24's Avatar
If you realy feel like fighting it, it can be done without removeing the drive are bellhousing, once you figure out the method its not too bad. I use a grabber tool(chinese fingers) to hold the bolt while I turn it with an open end wrench just to get it started then use the flex socket. you need a flex socket(7/16) not a flex extension, the flex extension and socket combo won't fit. Good luck
hillbilly24 is offline
Old 05-13-2005, 10:30 AM
I have replaced the limit switch by just installing the kit which is the guts only. At one time you could only get the limit switch as a whole set with wire and all.
wildcard1 is offline
Old 05-13-2005, 10:37 AM
I believe they only sell it as a compete kit now, most of the time the wires are what fails anyway.
Old 05-13-2005, 03:45 PM
Yes its my wires that are broke I think Ill buy the socket for the pins and lower the housing. Thanks for your help.
JIMB is offline
Old 05-13-2005, 07:32 PM
Dave M's Avatar
Do you really need a trim limit? My boat does not have one.
Dave M is offline
Old 05-13-2005, 07:59 PM
You should have one, it prevents you from tirmming the dirve too high while running, wich can cuase u-joint damage.
Old 05-13-2005, 09:04 PM
zt260's Avatar
I run an HP transom and there is no trim limiter. Why would you need one? You twist the U-joint more just by steering hard....
Not to mention I've run 700-1200HP through these U joints and never hurt one. From experience the gears will fail long before the U-joint will.
zt260 is offline
Old 05-13-2005, 10:42 PM
You don't typically turn full lock at WOT, at least I hope you dont The U-joints do bind past a certian point, Nxt time you have your drive off, try turning the input shaft with the u-joints in a flexed position, past a certian point they will turn in an eliptical motion and thats cuase they are binding, The drive can also be tilted to a more extreme angle then it can be turned. No the HP gimbals don't have Trim Limiters, I don't know the reasoning behind that, If you can get ahold of Mr. Gadgets on here, he might have some info on that.
Quick Reply: Limit and Trim Switch Install
