Tech Tip - THE IMPORTANCE OF PROPER ROD BOLT STRETCH/TORQUE
Only the Best Will Do!
Whether measured by stretch or by torque, properly preloading a rod bolt is essential for trouble-free performance. If a bolt is installed without sufficient pre-load (or pre-stretch), every revolution of the crankshaft will cause a separation between the connecting rod and rod cap. This imposes additional stretch in the bolt. The stretch disappears when the load is removed on each revolution, or cycle. This cycle stretching and relaxing can cause the bolt to fail due to fatigue, just like a paper clip that is bent back and forth by hand repeatedly. To prevent this condition, the bolt's pre-load must be greater than the load caused by engine operation.......
Download the attached PDF file to view or print the rest of this article.
