Mesa Racing Engines Latest Project
A to Z
Originally Posted by MESABALANCING
Ok guys we've been busy and haven't been posting but here is our latest project arrived yesterday we're building a pair of twin turbo big block aluminum chevy EFI engines they're going to be 380 ci as planed so far and we expect to make in the 1300 t0 1400 hp I'm going to document and show as much as possible and at the end we'll see how close we come . The customer wants to run 170s and have the fastest accelerating boat he's aver had we're going to give it our all . Also all the wiring for the dash panels we'll be finishing for him. Hope you gear heads enjoy . Sincerely Laz Mesa
sweet....
![Cool](/forums/images/smilies/cool.gif)
Originally Posted by DanB
The've been using twin turbo motors in the boats that pull speed skiers on the west coast for years. Everyone out there uses them. I dont know the specs but I think Pfaff started the craze many years ago. Ive seen them accelerate and they are quick!!!!!
Race after race, they just keep on gettin it on
Originally Posted by PatriYacht
Powerboat magazine did a story about that engine a few years ago. I still have it somewhere. The engines put out big power but the outdrives couldn't take it. That was before #6 outdrives. Btw, the guy that built the exhaust for that boat lives in my neighborhood and does welding and fabrication still.
Originally Posted by Dueclaws
Laz-
Who built the hull?
Due
Who built the hull?
Due
Here are some pics of the exhaust mods we've done you can see the first most noticed is the replacement Garret water cooled ball bearing turbo then the modification to the exhaust with the Tyal adjustable waste gate operated by an Innovative boost controller on the dash that controls both engines at the same time and the addition of the merge type collector flange which we use in the drag race engines I'm confident in the exhaust system alone we have another 100 hp to safely use. Hope you guys enjoy.
Originally Posted by sutphen30
i can see that working in a car,,and i know thermotec wrap work well,,but the heat from that set up at 1000+hp is going to be extreme.is there a plan for putting a water jacket around those pipes???
i do little 2.2l audi turbo motors and at 500hp to the ground,,our exhaust systems glowwwwwww
very pretty at nite.
garrett makes the water jacketed exhaust turbo housing but they want some bucks for it,,![EEK!](/forums/images/smilies/eek.gif)
i can see the center section of the turbo is water cooled..i' m saying,,the exhaust turbine housing is not water jacketed,,like gentry and other marine diesel turboes.why aren't you using them????
instigator
The water cooled turbine housings are incredibly heavy..... you can't hang those out there on the pipe setups he has showing... they'll crack, and break the flanges right off.... those turbo's are nice pieces, wrap the exhaust and run it...
My only concern would be turbine tip speed, at 8500 rpm engine speed, for loooong distances, your talking over 225,000 rpm on a T5 or T6 frame turbine wheel diameter. The trick is the tubing size, and a/r ratio's matching up...
I wanted to do this setup last year for my Criterion, using a 366" truck block (I have an NOS 366" tall block on the shelf now) .125 over, 3.766 crank, alum. heads, EFI, Hogan intake, maybe 385"-395", single BB turbo, intercooled.... my wallet dried up. I think a 447" may be a better way to go now... JMHO.
Jim Haas
Diesel Power & Injection, Inc.
Miami, Fla.
Jim Haas
Miami, Fla.
