Black Carbon Plugs >
Black Carbon Plugs
Black Carbon Plugs
Old 05-31-2005, 06:41 AM
cigrocket's Avatar
Default Black Carbon Plugs
My Hp500 started up this season with no problems. The motor has 132hours on it since new. After 1/10 of an our it started running rough and missing, it stalled a few times. I got it back to the dock and on the trailer. I pulled the plugs and they were carbon filled. I changed them out and put in ne AC DELCO Mr43T plugs. The boat ran great for the rest of the day. The boat sat a week. I started the boat and it ran a little rough, skipped a few times. Then was ok, ran it for another 15 minutes or so and decided to pull a plug. The plugs were all the same as before, dry carbon, solid black., the plugs are the correct ones, the wires are new, cap and rotor are also. Could the choke be causing this, or is the carb out of adjustment?? Any help would be greatly apreciated. I know the motors are better running a little rich but I should fol plugs after 15 minutes.
cigrocket is offline
Old 05-31-2005, 06:51 AM
cigrocket's Avatar
Default Re: Black Carbon Plugs
Could it be the choke heater, if so how can I easily check it? Or doesn't this sound like a choke issue
Old 05-31-2005, 09:32 AM
baja36ft's Avatar
I Don't Use Mr43t In My Hp's Use Ngk-ur5(v-power)
Much Better Plug And Once The Motor Warms Up
Take The Air Cleaner Off And See If The Choke
Is All The Way Open. I Took My Choke Off.
baja36ft is offline
Old 05-31-2005, 09:56 AM
Charter Member #30
Scott's Avatar
I do use MR43's in mine and have never fouled a plug. I would also start looking at the choke.
I have Steps & Bubbles!
Scott is offline
Old 05-31-2005, 10:00 AM
cigrocket's Avatar
Could the choke just be gumed up, should I spray some choke cleaner.on it.
Old 05-31-2005, 10:08 AM
baja36ft's Avatar
let the motor warm up and take the air cleaner off and the choke should be open. if it's not then thats you'r problem.
baja36ft is offline
Old 05-31-2005, 11:18 AM
velocitypwrbtr's Avatar
Idle mixture is too rich causing your plugs to fowl. Turn in your idle mixture screws and back out 1 1/2 turns to start. Use a vacuum gage to obtain maximum pressure. Make sure that you set all of the idle screws and don't forget to count number of turns in.
velocitypwrbtr is offline
Old 05-31-2005, 12:27 PM
cigrocket's Avatar
How many idle mixture screws are there
Old 05-31-2005, 03:36 PM
Received 1,938 Likes on 976 Posts
Just get a small wire tie and wire the choke open. See if it solves the problem and go from there.
Griff is offline
Old 05-31-2005, 04:59 PM
Charter Member#330
MrCIG's Avatar
Do you have fuel pressure guages? If it's a mechanical fuel pump soemtimes they make to much pressure as they get old and will push fuel passed the needles and seats in the carb. Just had one do it changed the fuel pump and all is better.
Oh ya the fuel pump was a Holley only 1 year old.
Mark
MrCIG is offline
Quick Reply: Black Carbon Plugs
