Best twin turbo motor manufacturer?
#31
I heard theres interest on DEAN DELLNERS 698CU blower motor that would beeven sicker with that blower turbo set up
wow. I just wished when I decided to go with the 572 he had the 698 for sale
, talk about low end tq with 698 cu wow. thats a real bravo killer. man anyone want a 572 1071 going together as we speak only if I can get the 698 but theres a person or two in front of me some one getting a sweat deal. whats the cost of a twin turbo set up like a 1071 might be 5gs for a blower a whipple 10 gs a twin turbo???? anyone
![EEK!](/forums/images/smilies/eek.gif)
![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
I think you might be surprised how much is made with theses twin turbo 572's
![Drink](/forums/images/smilies/drink.gif)
![Ernaehrung004](/forums/images/smilies/ernaehrung004.gif)
Jon
#32
#34
Just food for thought, but my naturally aspirated 572's with 9.5 compression and 1150 dominator's make 650 hp. and torque to match.
By 1,850 RPM's with these twin turbo's we are making more torque, than my naturally aspirated 572 ever make at peak torque.
#6 drives are in order, rather than anything along a bravo platform.
Jon
#35
#36
Treat it like a good woman, ez on ez off.
I have a twin turbo 572 in a Nordic rage with a Imco Extreme drive and havent broke it yet. The motor has two gt47 turbos and at 10 lbs boost on pump gas its about 11 to 1200 hp.
#37
Chris
Chris
#38
#39
HERE IS A COPY ABOUT THE COMPUND BOOSTPOWER TWIN SUPERCHARGED-TWIN TURBO EFI CUSTOM ENGINE.
THANKS
Hello Folks! This is the latest in custom EFI Marine engines. This is an all polished aluminum 600+ Cubic Inch Twin Supercharged, Twin Turbo, Intercooled, Digitally Fuel Injected Lightweight Monster. Like the last one we did, this one is due to make 2200+BHP on racing gasoline. This motor was inspired by Hank Sahagians twin Roots blower set up from the 60's along with several aviation applications built in the past. The concept is the superchargers eliminate any lag time and increase the low end torque curve. The twin turbos quiet the engine along with add additional Boost to the engine. The beuty of the set up is that the engine will have 3 settings. Setting 1 for pump gas at 900+hp. In this mode the engine will primarily run from the superchargers and the turbo boost is computer controlled to bypass to the atmosphere. Setting 2 will be 1400+hp on race gas of 115+ octane. This setting allows some turbo boost into the engine along with a more agressive timing and fuel curve. This mode will likley have double the acceleration. Setting 3 will be Full Race Mode. This setting will allow the preset regulated turbo boost to feed the superchargers and similar to the last one we did will put close to 30 psi in the motor with ease. The expected BHP willbe over 2200. Keep in mind this is a dry sump High RPM engine with a very low static compression. Basically it is built to accelerate. The motor weight is lighter than most conventional big blocks with a 14lb flywheel to boot. Stay tuned to see this product released in early April as a custom built to order race machine! (NOTE: PICTURE DOES NOT SHOW TURBOS MOUNTED YET)
THANKS
#40
THANKS
THANKS
Thanks and nice work!
Jon
