Type of Gil Manifolds??
Can someone identify these Gil Manifolds?? I've just never seen them before.
Would these be Gil's standard aluminum elbows?? The inside of the elbow is a larger diameter than the inside of the tail pipes. Connection between elbows and custom tailpipes is sealed with a metal doughnut that also acts like a reducer between the two. Longer curve to the elbow than the SS elbows fo course, but larger inside diameter -- better or worse flow than standard SS elbows??? Do they still make 'em ??
That is the Gil Magnum Sport 2-Piece Manifold & Riser. The 2-piece risers are cast aluminum and were set up with either a straight or 14 deg down stainless tailpipipe. The 14 degree down was for a standard location Bravo and the straight was for a standard location TRS.
This particular riser has not been manufactured since the early 90's although Gil did still have stock on them as late as 96 if my memory of my time working for them is still correct.
