Need Timing Specs 1994 502 Mag
I Need Timing Specs For A 1994 502 Mag. From Idle To 3000 -3500Rpm. Also What Should The Clyinder Compression Be?? Thanks
If it is a Thuderbolt IV ignition system, the advance curve is determined by the ignition module. Pretty sure it has the V8-20r module. See chart below. Compression should be about 160PSI.
Dave
Dave
