lost comprsion on a cylinder or two any ideas 2000 454 mag >
Old 06-29-2005, 08:40 AM
Default Re: lost comprsion on a cylinder or two any ideas 2000 454 mag
Possible overheat and low compression on 2 adjacent cylinders, sounds like head gasket. Not too big of a job. Pull all plugs and run a leakdown.
Gary Anderson is offline
Old 06-29-2005, 09:31 AM
Smitty's Avatar
Head gasket between center cylinders is my guess
Smitty is offline
Old 06-29-2005, 10:11 AM
liquid asset's Avatar
what and how do you do a leak down?
liquid asset is offline
Old 06-29-2005, 10:31 AM
Dave_N's Avatar
Some good info about compression and compression leakdown tests/testers in this thread.
http://www.offshoreonly.com/forums/s...d.php?t=106452
Dave
Dave_N is offline
Old 06-29-2005, 10:43 AM
If you dont have a leakdown tester (I suspect you dont since you're asking), but do have a compression guage, do this.
Turn engine so that low psi cylinder is at TDC compression, valves must be completely closed. Use your comression guage hose to pressurize cylinder to around 50psi. Now listen to where the air is coming from.
If it's from the adjacent cylinder, you've got a bad head gasket. If from the intake/carb or exhaust, it's a bad valve. If from the breather, it's going by the rings. If from the blocks water jacket, cracked head or head gasket.
Gary
Old 06-29-2005, 05:28 PM
If your hose has a check valve in it,
You'll need to remove it.
JaayTeee is offline
Old 06-29-2005, 11:09 PM
I appreciate all the info guys, keep it coming , I am tearing it down now, and redid comp test and the outside had 125 on all 4 and the inside had 125 on front 112 on 2nd, 45 on 3rd, and 125 on fourth
Old 06-30-2005, 12:47 AM
Dave_N's Avatar
I'm still guessing water intrusion. If the exhaust manifolds are original, they are due for replacement.
Dave
Dave_N is offline
Old 06-30-2005, 08:57 PM
I got it tore down and it had broke a valve seat, I got that fixed and am putting it back together now
Old 07-04-2005, 04:31 PM
Now I have water in the oil, like full, I guess that could mean I f'ed up the intake gasket?
Quick Reply: lost comprsion on a cylinder or two any ideas 2000 454 mag
