Bravo alignment with Offshore mounts?
Charter Member #655
same couplers, same u joints,same mounts, Tinkerboater is going to bring his alignment tool over tonight that way I know where to start.
If your boat has a sail do you ride a horse to the ramp?
Did you put the mounts on the same side they were before. The L angles are drilled to align the front of the engine. Subtle changes can have big effects.
Use an alignment tool. See what needs to be changed.
You can make a 3 hole or slotted shim to put between the mount and engine if it's minor.
If major changes are needed, redrill the L angles.
Gary
Gary
Offshoreonly Advertiser
New flywheel housings? The latest version does not use spring washer.
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
Charter Member #30
I see you got it fixed although I can't imagine Foul being any help
Can you let us know what you had to do to take care of the problem?
![Cool](/forums/images/smilies/cool.gif)
I have Steps & Bubbles!
Can you let us know what you had to do to take care of the problem?![Cool](/forums/images/smilies/cool.gif)
Charter Member #655
Mike was great moron support! we got it handled last night, took everything lose and used and alignment tool, all set ! Thank God!!!
SORE MEMBER
1 Post
Come on Dyno, your not telling us what you found!! We need to learn from your experience.
"Chasing knowledge" one post at a time
![Evil](/forums/images/smilies/evilB.gif)
![Stick Out Tongue](/forums/images/smilies/tongue.gif)
Charter Member #655
I just took all the bolts lose replaced two of them with a tapered pin jumped up and down on them a couple times and bingo! engine aligned.That was the port motor the starboard just needed the gimbal bearing straightened out with the alingment tool.
